Those came with the HPI Heavy VVC/HD Shocks. You can use the shafts and pistons with Redcat cylinders. I only used the shaft boot and the piston. The shafts are from Dark Soul racing. The cylinders and caps are from Redcat. Forgot to mention the DDM springs...MTMIKE said:Where did you get the rubber boots covering the CVA joints?
I believe the shafts are fronts all around. I actually got them from a member on this forum (Deluge). So I didn't actually have do the math, that was already done for me. But as far as the Caps and bodies go, I bought just the caps from Redcat (Parts dept had a set to sell) & installed them on my factory bodies.Ildy666 said:What size length are the shafts? Are they baja fronts for front and baja rears for.the rear or fronts all around or rears all around?I'm asking because I'm going to build my own also.
I've seen 8 mm diameter shafts just want to get the right length
Also can u just buy the res. Caps and bodies or do u buy the shock and Frankenstein from there?What weight oil did u use? I was going to use 40 weight oil would that be good for bashing?
