Hi,
I am new to 1/5th scale and I really don't know a lot about engines in general so please I know that my questions might be stupid but still please help me out.
I got my Rampage XB about 2 weeks ago and have already made a few modification with the help of a lot of the posts on here. I replaced the servos with Hitech's. I replaced the radio with a Spektrum. I added a KillerBee kill-switch.
Now to my questions:
1) I have run my car through about 3 tanks and when ever I got down to like the last 4th of a tank my idle starts being higher meaning I have to push the breaks for it to not drive away.
2) Ok I will try to explain this issue as best as possible. I think my engine is spitting out some stuff on the left side. The first 2 images highlights the area in red. When the engine is running I can feel air coming from some place there. The third image I am trying to show how my stock pipe is not straight I don't know if that has something to do with it but just wanted to mention it. In the last image I am showing how it looks like after running. You can see the stuff that it spit into the body on that side and also reflected back onto the gas tank.
3) I am looking to buy the HPI Baja wheel adapters in order to use Baja Wheels. I found pretty cheap premounted tires:
http://cgi.ebay.com/HPI-4743-Mounted-Tarmac-Buster-Rib-Rear-Tires-Baja-5B-/380321186007?pt=Radio_Control_Parts_Accessories&hash=item588ce8c0d7
Is it a better idea to buy wheel/tires and so on separate or will I be able to reuse the wheels for new tires later on?
4) The last issue I have (probably just for now) is that if I jump it, it always bottoms out. Is there a way to adjust it or replace a part(s) to not make it bottom out any more or does it not matter?
If you need any more help or if you want me to try something I will be happy to try.
Thanks,
Andreas
Thanks,
Andreas
