New version of gear set?
that is the upgrade for the older V1/V2. It is now stock on all models. It has the steel brake hub instead of aluminum brake hub.
Deluge said:
How are they different? Those are just regular gear hubs.
I striped my set screw on the hub that is holding the pinon gear to the crown gear. The only way is to replace that hub along with the set screw that is striped or try to take out the set screw. My question is, is this part # correct for fixing my problem?
