nitro guy need help bad
fastlane
Estherwood, La.
well I started it today and it ran fine but the primer bulb was empty, I fixed that problem and now she wont start at all. It seems to be flooded. or somethin
If you over primed it, it could be flooded all you need to do is pull out the plug crank over the engine couple times dry off plug reinstall the plug. shouldn't be any real problems after that.
When mine gets flooded I do like a real car open the choke all the way, hold the throttle all the way open (floored), and crank and crank and crank until I hear it stumble a few times. Then I close the choke, leave the throttle alone, and start it like normal. I have not had any luck with the pulling the plug method.
Yep that"s what I did. I treated it like a flooded weedeater and I"ll be damn it worked. I just got nervous because I put the engine together and it was My first time. In the end it was a success! That baby runs like a champ.
