Sharkey
- Abbotsford BC Canada
since i have my sportsline mostly built and running like a champ, its time for another project. ive had my nitro tc3 now since 2004, its been upgraded with a version 2 rear suspension and a few choice suspension upgrades, but aside from that, the rolling chassis remains pretty much stock. over the years its had quite a few engines. it started life with the hpi/novarossi 12 from my old nitro rs4. i ran the car for a couple months then in went a rossi pixi black .12, and i raced it that way till 2007, and bashed till 2009. with the motor tired, i tossed in an old os .15cvr, when that died i ran a traxxas motor for a bit, then rebuilt the pixi after finally finding parts. just after break in the piston cracked, unable to find another piston and sleeve i retired the motor for good, and moved on. not racing anymore, knowing i wouldnt be satisfied with the power of a cheap smallblock, i decided bigblock was the way to go. i purchased a rossi t6 .21 for $40 brand new, fabbed some mounts, and in it went. diffs didnt last long, i ended up with a set of dynotech racing aluminum ring and pinions, and played around with the gearing, it all worked quite well. unfortunately the first large scale outing of the year was the last for this combo, the connecting rod finally had enough of the extreme rpm the motor was pulling on the large track, the bottom of the rod stretched and the rod bushing fell out. i thought about another .21, however as fun as 80mph with a touring car was, doing it again seems pointless. i tossed around the thought of retiring the car, however its sort of my "project x" (any car guy will know what project x is), it'll keep going till i find the perfect combo.
a couple pics of it with the .21
this brings me to the beginning of the next phase. years ago i always like the os 4 stroke car motor. something different. however the low advertised power, amount of custom work, and the price kept me away, like many people. well, years later ive got bit by the bug again. however the fs 26s-c has been discontinued since 2009, there are none around anymore. now you can convert an fs30s airplane motor by changing the camshaft and valve springs, however the camshaft isnt available. this led me in the direction im taking. ive purchased a used fs 40 surpass 4 stroke, and have tracked down the crank, cam and head from the fs 40s-c car motor to convert it to the car spec motor. i figured the .40 4 stroke was a replacement for a .21, and the tc3 has a .21, so it'll work out. this project isnt about being the fastest, or best handing, since i quit racing its been all about fun, and the 4 stroke seems fun.
so far ive mocked the motor up in the car and figured out gearing. the 4 stroke has a max rpm of 22000, however modded they have been dynoed at over 26000rpm. being the torque of a 4 stroke and low rpm, gearing is key. with the .21 i had machined the 2 speed clutch hub and one way bearing for hpi 37 and 41 tooth spur gears, and ran 19/23 tooth pinions on an hpi clutch bell, so gearing is quite tall already, but would limit the 4 stroke to around 42mph. scared of valve float i dug around and found a 29 tooth savage metal tranny gear that with some machining will thread onto the clutch bell. couple that with a revo 36 tooth 2nd gear spur, and it comes out with a 3.10 final drive ratio, should be enough for 60mph.
im waiting for a bunch of parts for the motor, both for the conversion and just general rebuild stuff. its getting the car crank, cam, head and intake, along with a set of crank bearings, cam followers and pushrod tube seals. im planning on running a 10e rotary carb to start with and eventually move up to an hpi composite k4.6 carb. ill be building my own header, ive been reading about how well these motors respond to a stepped header with a megaphone end (read: almost double the power output, dyno confirmed). ill start with that, ive read about some more tricks with these motors, ill wait till i get it all figured out before screwing with it more.
ill leave you with a couple of pics of it thus far
