No movement with throttle
Boriqua935
Ok it's not the clutch. Took all apart, clutch still has alot of shoe left on it. Checked all pins on wheels cups, checked grub screw by brakes. Everythig is tight. Any other ideas? When I idle truck will not move
What do you mean it won't move when at idle? Are you trying to push it and it won't roll? Or are does it not move when you hit the gas?
If it won't move when you accelerate, and you've checked all of the pins and the brakes. I would start looking at the gear plate and make sure the square hubs that the gears mount onto aren't slipping. There are set screws in there, as well.
Sorry that's what I meant. Won't move when given throttle. Checking the hubs was my next step. Thanks
I had a problem that sounds the same as yours...
It's like it's stuck in neutral right? Just reving as you give it throttle?
I made a video on what I did to fix that. I hope it helps you
[ame]
[/ame]
I use Red locktite...just a little...you can always heat it up with a solder iron to remove...Crazy glue I'm not so sure.
