No power to the wheels
chefjness
What do you think guys. Was running the MT and all systems were great. It was running sweet. All of a sudden no powere to the wheels and engine was running. Topically looking at it, all the gears and dogbones are functioning. When I spin the clutch bell with my finger the tires spin. Can this be worn clutch shoes?
Cheers,
John
Loose set screws on the clutch bell, loose set screws on the last shaft the one with the breaks on it, clutch shoes maybe, but not likely. I would check all set screws. Give it a good look over start where the power is put to the drive line that would be gear A then B then C then D, then follow the power to each axle. You'll find out what is the problem.
so when you spin the clutch bell the tires spin? i was first going to sugjest the grub screws that hold the gear hexes down, but it may be your clutch. if it was the spring it would be engaged all the time. pull the clutch off and see how much skin is left. also spin the clutch and make sure its tuning the piston.
