I've been in RC for over 30 years. I have a G320 Zendoah engine that lacks in take off speed. It will not spin tires. Engine starts and runs well. Temps are good. I will reach top end but takes a flat surface to reach. I have zero get up power. Engine has probably 2 gallons thru it. Things I've done to fix this issue. New plug, Cleaned carb many times, installed tuned pipe, went 1 tooth smaller on pinion, high flow filter with velocity stack and tried various clutch set-ups. I have good compression. I've tried various fuels. Nothing seems to fix this issue. When it was new it was a beast and quick off the line. Now it just lags to reach speed and cannot climb any sort of hill or jumps. The one thing that stands out to me is...A few times I have sucked in clayish dust from being in the south...Hence why I've cleaned the carb so much...But if it starts and eventually reaches top speed...I feel something else is wrong...Any ideas?
