Nomadio React 2.4 ghz radio
Nomadio Specification
Radio Type: digital spread spectrum 2.4 GHz
Radio Mode: frequency hopping spread spectrum (FHDSS) and direct sequence spread spectrum (DSSS)
Game Mode: Though the USB cable to PC seen as game controller / joystick
Range: 1000ft.
Power Output: 100mW FHDSS / 10mW DSSS
Frame Rate: 100 frames per second FHDSS / 50 frames in DSSS
Total Latency: 5 millisecond max, 2ms typical
Weight (w/Batteries): approximately 18 oz.
Servo Channels: 4
Four cell re-chargeable battery
Model Memory: 20 named
Controller Battery: Voltage Monitor: graphic and real-time
Receiver Battery: Voltage Monitor: graphic and real-time
Timers: Operation and lap timers
Trims: Adjustable trims and sub-trims
Controls: Dual rate, endpoints, exponential, advanced brake mixing and servo speed adjust on all channels
Anti-Lock: Brake anti-lock with adjustable trigger, cycle, delay, depth, and steering trigger
Idle Up: yes
Tactile Alarm: programmable vibrator
Display: Graphic LCD
Resolution: 128 x 64 pixels
Auto Modes: auto display and display only
Presets: Failsafe and auto start
Telemetry: Real time speed, temperature, and battery supported (sensors purchased separately)
Servos Supported: Any combination of analog and digital
PC Connectivity: USB serial for charging, customization, analysis and updates
Antenna: Built in
Architecture: software upgradeable
whats included
Nomadio react radio
2 tranceivers
3 batteries
usb lead
original box
it also has a carbon wrap
£170 posted in the uk will ship outside uk for extra cost
LRP A2-STX PRO 2.4GHZ F.H.S.S
The little brother of the successful C3-STX Pro 2.4GHz impresses with its 2.4GHz system and the A3-RX 3-channel receiver, able to manage 7.4V input voltage, through extremely high reliability and outstanding transmission security. Problems with occupied frequencies are now finally a thing of the past!
Crystal- and Interference-Free 2.4GHz Technology
Due to the 2.4GHz technology you do not need to worry any longer about radio interferences. Problems with busy frequencies are history!
End Point Adjustment (EPA)
EPA adjusts the maximum angle causing a different turning radius. It is used to adjust the maximum servo travel for each channel and turning direction in order to protect your servos against damages due to overturning of the servo above the technical limited servo travel of your vehicle.
Fail Safe Function
FailSafe sets channel 2 to an upfront defined position in case of a weak or lost radio signal in order to avoid loosing control of your vehicle. If no pre-setting is done Failsafe is set to neutral position.
LRP Quality in a complete package
• New 2.4GHz technology
• 2.4GHz FHSS 3-channel receiver
• LED battery status display
• Ergonomical gun grip and steering wheel design
• Outstanding price/performance ratio
• Charge socket for optional rechargeable batteries
this is brand new never used and has an rrp of £51.99
£40 posted will post outside the uk for additional cost
MRC superbrain 960
FEATURES
• AC/DC Delta Peak charger with MicroPeak Technology
• LCD displays five readings: Battery Status, Battery Voltage (V), Charge Current (A),
Charging Time in minutes (Min), and Delta Peak Voltage Threshold in millivolts (mV)
• Charges Nickel Cadmium and Nickel Metal Hydride batteries
• For 3~8 cell AA and sub-C packs, plus a special setting for single cell “Glow Driver”
battery (single-cell)
• Nine charge current rates:
0.5Amp to 4.5Amp with 0.5Amp increments
• Fourteen delta peak voltage thresholds:
5mV to 70mV with 5mV increments
• Plug ‘n Play Operation for sub-C or larger battery cell(s)
• 12-bit Analog to Digital Converter greatly improves measurement resolution
• Digital Signal Processing (DSP) filters out noise and provides greater measurement
accuracy
• Compact size to fit into a field box
also comes with a multicharge lead and original box
Range: 1000ft.
Servo Channels: 4
Idle Up: yes
Antenna: Built in
whats included
Nomadio react radio
2 tranceivers
3 batteries
usb lead
original box
Fail Safe Function
MRC superbrain 960
FEATURES
accuracy
