aelliott70
I'm a total noob to 5th scale (and gas engines). I haven't had an RC car in 30 years. I Wanted to get back into it, and why not go with something I've always wanted, a large scale gas RC, so I went with a DBXL 2.0. I stumbled on a good deal on a preowned rig at my local hobby shop, and pulled the trigger. I've been driving it for about 3 months without issue. I never even tuned it. The mechanic at the hobby shop tuned it for me, but that was in August, and using the VP premixed fuel. I've since switched to pump fuel, and its gotten COLD. The engine started running like crap, and a lot of smoke. Figured I have to learn sooner or later to tune my car.
I started by starting the car the way it was on a stand, and letting it sit there and idle for 10 minutes to get warmed up. Shut it down, then reset everything to factory. Turned the Idle screw all the way out until it barely touched the throttle. Reset H/L back to factory, and pulled the starter.
So glad it was on a stand. The wheels immediately took off spinning! When I hit the breaks, the car stalled and shut down. I turned the Idle screw in a turn, then repeated. This repeated until I got the idle in far enough it didn't turn the engine off when I hit the breaks (but wheels still spun at start). Then I started increasing the LOW (richer) until I got the idle where I wanted. Wheels not spinning at startup, and rich enough it would idle about 20-30sec then shut off, unless I gave it some gas.
Then I started on the HIGH needle. I hit full throttle and the car shut off. I increased H (Richer), and restarted. Hit throttle, it shut down again. I increased H. This repeated until it stopped shutting down, and the RPM's were climbing with each increase in H. I finally got it to where I think I had maxed out the RPM's, and just to be sure I pulled the throttle all the way back and held it for roughly 30-40 sec maybe... then it just stopped! When I went to pull the starter, this time it wouldn't budge! I waited a couple hours to let it cool all the way down, and still it wouldn't budge.
Is this engine toast as in throw it in the trash and buy another? Is there something I should check? Can this thing even be rebuilt?
