not again
bensonly
Contributor
tulsa ok area
was preping truck for new parts to show up. well found more wrong.
1 on off switch melted.
2 rx(stock) melted
3 some wires close to melted.
4 found out center diff grub screw was lost
5 adding billet moter mount and broke 2 allen wrenches.
not my day.
going to up grade tx/rx if any localy ava.
what brands models should i look into/ stay away from.
on a budget also.
thank you all.
spektrum dx3e. 3 channel fully adjustable. $99 includes tx rx and a standard size servo. i love mine and for the money it is hard to beat. i have had mine for a year now and never a single glitch. and its nice and light(only 4 aa batterys)
agree! its perfect for the money
They use a ton of locktite from the factory on the gearplate and bottom motor mount bolts. I learned to use a small blowtorch to heat them which loosens the locktite. Othewise you'll strip the hex or bend an allen every time.
Bensonly I put the billet motor mount on also and the holes were off alittle I opened the holes alittle with a drill bit and when I went to bolt it up iIstripped the allen head bolts like you said.
