Not Good!!
Ludabud
Wyoming County, New York
well i was running my truck today and it was running good all day till i burned out a dif cup and when i looked a the truck after i got home i seen that one of the muffler bolts was gone....so i took it off and noticed that it didnt fall out it broke off. so now i got part of the bolt left in the motor.
You may want to try an easy out if you cant grab it with vise grips or pliers.You could also try to drill it and tap it with left handed therads screw in a left handed screw and turn it out.
That really sucks!!!....what Cordy said, it's your only two options...I'd get and easy out drill tip from Home Depot and try that first...
Worst cast scenario, heads are real cheap...
