Nurchburgler Xb build
RCDAD said:
Looks good to me!
Thanks..but just not good enough for me.
1st attempt is going on the buggy...second attempt will come after I try this out a little.
Next attempt I might do 1.5mm on both sides of the stock tower..smaller weave...better cf
Nurchburgler said:
Carbon fiber towers...hmmmThe lesson I have learned is don't use cheap carbon fiber..more fiber glass than carbon....and I also learned that drilling this stuff makes it fray...
Gonna try a aluminum carbon fiber mix for now and make changes on the next set.
The tower looked alright till I drilled it :(
Oh we'll
Did you make that using the dremel router???
RCDAD said:
The two sandwiched together should be plenty strong.
Yeah..I used a dremel router table
Gonna sandwich them together as a temporary solution..gonna make a nice set at my leisure or I may have a small run Made of 5mm - 6mm towers.
Looking into it now ;)
From what I have been reading carbon fiber bonded to aluminum will cause a discontinuous metal condition..causing corosion...the molecules don't make friendly ;)
However as a temporary solution it will be (yoda)
Build coming hopefully Monday ;)
Chassis gonna wait for sale :)
Finished making first run of half carbon half aluminum 6mm towers.
They are a little rough..learning lol!
My advice is get a lot of bits..the carbide bits cut nice but dull quick and fray the fiber when dull.
Gonna get concave washers for front tower to cover up fray and just ugliness lol!
Last pic is of out drive cup rings.
Thanks to big fol
Would a couple layers of masking tape over the carbon help with the fraying? I am liking the carbon rings, they look pretty sweet!
Nurchburgler said:
Finished making first run of half carbon half aluminum 6mm towers.They are a little rough..learning lol!
Thanks to big fol
Did you make or buy the rings?
Prolly..the rear tower I drilled from the front and the front tower I drilled from the rear.
Learned that the bit busting thought he fiber caused the fraying on the front one.
Also when doin the finish work sanding the edges it was best to leave about a 1/16 inch and then use the original metal one as a guide to get a smooth sanding line.
My next towers I will do all carbon fiber.
Bigfol has a thread talking about these rings. Bought the carbon fiber tube from china on eBay (took a while to get here)
Cut em...and gonna epoxy em to my cups
