oil or grease in front diff?
mudpy
Junior Member
Hey guys i have to replace my front diff covers is there oil or grease inside and where do i buy it ? thanks
Diff lube, safe cleaning solvent.
I have the XB buggy.- I run 10,000 wt rear. - 7,500 front, In dry loose conditions. 15,000 wt rear, - 10,000 front, when there is some moisture in the ground. The sano way to get the factory fluid out -- buy a quart of Denatured Alcohol, disassemble and soak in a container for about 1/4 hour. the hardware store should also have affordable acid brushes- disposable-25-50 cents - this helps to clean up the diffs-gears too.
Thanks guys also does anyone know where i can get the front diff covers for the dunerunner v-3? they are out of stock from redcat and i can't seem to find them
thanks
