old rally
Jackson gt2
ok i want a onroad rally for a while now and having a bunch of spare parts laying around i was thinking why not?
so does any one knows exactly what parts the old rally share in comum with the rampage and the exactly wheel base of it is it the same as the rampage chassis?
thanks guys
I can't help you with your question but was also curious about what the wheel base of the new rally was and if it would be possible to use the body on an m/t. from looking at pictures it kind of seems the body posts are located in a similar way.
i realy believe that the old rally car is just the same mt chassis with a few maybe different suspension arms and shock towers but am not sure!!!
It's not the same mt chassis. Before RCDAD disappeared he had 7075RC build him a rally chassis so old fart would know the specs but the stock chassis is flat more like the XT . Look under RCDAD'S projects you will see 2 side by side.
My MT and rally both have a wheelbase of 516 mm and share all parts except wheels/tires, gearing, and body.
Full Specs are:
Length = 760 mm
Width = 600
Height = 350
Wheel base = 516
Ground clearance = 72
Wheel Diam MT= 212 - Rally = 178
Wheel Width MT= 140 - Rally = 80
The new Rally has a wheelbase of 505 mm.
Full specs are:
Length = 860 mm
Width = 450
Height = 280
WB = 505
Ground Clearance = 40
Wheel Diam = 155
Wheel Width = 62
Gear ratio = 1:12.3
