One piece tuning pipe?
waqr
Sweden
I am having a very hard time deciding what pipe to buy for my FG Monster. Thinking of the DDM Dominator and Jetpro but don`t these one piece pipes stress the chassie and engine mounting bolts much more than pipes that have two pieces (which means that they flex more).
hi i had the same problem to so i went shopping at ams for the tgn and got this one and love it. nice sound and makes a hell of a difference its the fourth one down on the left
http://www.a-m-s.ch/shopenams/tuning-grossmodelle/fg-tuning/resos/index.html
but if you want to put a beetle body you will have to change the angel of the manifold a bit but for the normal mt body this is not the case
hope this helps
What are you looking for out of your MT? All the pipe will be different in sound and performance. I can tell you the 3 piece FG will give you great mid to high but not the best on low RPM's and the noise will be less due to its manufacturing. The DDM pipe will be way noisier but will give you good low end and great mid. With the DDM you can wheelie at half throttle. You can hear a increase in power when it gets in the mid range. I would recommend bidding on the DDM on ebay. Two piece or one piece I don't personally find a bit of difference other then the 2 and 3 piece pipes can be a pain to keep from leaking or failing at the joints. Good luck on your decision no matter what pipe you finally get it is a world of difference.
get the JP V2 MT pipe ..
i had the JP V2 MB pipe and was great .. nothing exposed out the back and was braced at the front aswell as the sides ..
contact Tom Jr at python he has them in stock
