looks as if 1 of two things:
1) not enough grease in the diff or
2) one of the pins bent or broke in the diff.
yup the diff is now the weak link with a lot of torque from the engine....
I have 2 extra sets of internal gears for my rear diff......I figure you will go thru 2 sets
internal gears to 1 set of pinion & spur gears....The little diff gears are turning 3 times as fast as the bigger gears.......Yes.... FG gear are expensive....Slawhammer
Ducky good one! I have never seen a FG diff fail, and you did it. I would be curious to hear what FG had to say about it. How old is the diff?
I am using ball drives but the outer spline drives are slightly different as they hold the viscous plates, but interesting though on the other gears though as I think they are normal. I'm currently bidding (fleabay) on another LSD so if I get that cheap enough I won't bother repairing the viscous for now.
