ordered my new parts today
lsvtieg
I just ordered a kraken x2 chassis, turtle racing top plate, rpm front bumper & rpm rear bumper brace. Next thing I will order is a killer bee system when I get the extra money.
ah yes, well it sounds like its going to be a nice beast when its back together!
has it given you many issues that arnt to be expected?
hows the motor? is it a 30.5?
cheers :)
Haha, I've only had it less than a month & have run maybe 3-4 tanks thru it. Yes it is the 30.5cc motor & only problem I have had with it so far is the pull start. It makes good power even tho I'm not fully done tuning the motor yet. I can't keep rear tires on this thing, they keep flying apart or ripping at the inside beadlock. I guess I am a little hard on it tho but with the upgrades I've already done plus the upgrade parts coming in it be a pretty stout little buggy. I had already planned on replacing the chassis but didn't think I would be doing it so soon. I might as well replace the rear plates on it for preventative maintenance, but that will have to wait.
I did notice the day I fought the tree when going in a straight line the front wheels hardly touched the ground. It has some torque to it & sometimes when it shifts into 2nd the wheels really came up. I do need to work on the shift point tho. It's shifting a little too soon. & when turning at high speeds the outside wheel seems to wobble a bit so I need to try & figure out how to fix that. I really want to convert it over to sc tho.
Got my parts in today & she is back together. Took less than 2 hoursto put back together & man does that kraken chassis look tough! I need to do a slight modification to where the on off switch is tho. My finger doesn't fit in the slot. I will post some pics later when I take some.
Not really. Just weak materials. It was a relatively slow speed. Momentum man.
