46u
I had this in my HPI MT for a short time. It might have a gallon on it. I extended the pull starter handle to make it easier to get to in my MT. Can be run like it is or cut it down to you likings. I always use after run oil and engine has been stored inside. It comes with original box and instructions. Has very excellent compression! What all comes with it including engine new would cost around $370.00!
Only problem I had with it was keeping the front wheels on the ground when it was in my HPI MT!!!!!!!!!!
The pipe is the one OS recommend for this engine that is no longer made it is an OS Speed T-1040 R70. They still do make the T-1040 R52 with the smaller diameter stinger that sells for $80.99. The pipe on it with the bigger diameter stinger works much better then the 52.
OS air filter that sells for 36.99 and I installed an outer filter to make it 2 stage. I got these prices off Tower Hobbies web site
OS 18TZ-TX Turbo $199.00
OS Speed T-1040 R20 $80.99 which is not longer available!
HPI Racing 15 tooth CB $16.39
HPI header pipe $13.49
HPI racing clutch $11.59
Fly wheel $4.89
CB bearings $8.00
OS air filter 36.99
Total $372.33
Asking $175 shipped to the lower US 48 states. Will consider any resemble offer but please do not insult me.
Fly wheel $4.89
CB bearings $8.00
OS air filter 36.99
Total $372.33
