mcdracerunner
- skelmersdale
does any body know of a peak rpm counter so i can read the top rpm of my engine i know the oddie ecu has one but am not paying £200 just to use that function ??
check thru the boating forums. the most popular unit is the Sendac? (spelling). it rated to be good to 20k RPMs.
hth
T
Please explain that sensor..I not sure about that one..Thank you..You can switch to the Nomadio Sensor.
Check the like.
http://www.nomadio.net/hobby/sensor.php
It is a radio system with some cool fetchers.[/QUote|
Not too sure about this radio system..It just gives basic info for you RC Unit
I did not see any thing about rpm readings
AKA Slawhammer
the tachs most of the boating guys use are Inductive pickup, ie you wrap the units wire around the plug wire, and it senses the spark pulse traveling thru the wire. they work VERY good and all you need to do is wrap the units wire around the plug wire. no funky magnet setups, no running aditional power wires ect.. mount the take, wrap the plug wire with the pick up wire, turn it on and go.
http://www.amickssuperstore.com/ENM_2_Cycle_Two_Stroke_Tachometer_Tach_p/enm pt15b2 tachometer.htm
something i found but haven't called and ordered one
you are correct on this that is a reason i wanted to find out more info on the phone because it states its a 7 segment lcd .. i wasnt sure if it had reading into the 20 thousands . not that many motors rev that high but some do
Like I mentioned you want higher than 10,000 Rpm.engine unloaded WOT is 14,500 rpms..The Inductive is the way to go...i called today and was talking to a guy Tony there and there 27.95 up to 24,000 rpm with a 1.2 second refresh time meaning it changes rpm dispplay every 1.2 seconds .. you can get faster refresh timing rpm counters but at a much higher cost .. and i feel for my purpose this will be fine .. got 2 coming in a week as there outta stock at the moment but he said they get those counters in a week
