atom3624
- Cold, wet, windy St Helens, U.K.
I'm sure it's happened with many, if not most of you who don't use beadlocks, but I'm tired of having to clean, re-trim and re-cement tyres onto my FG MT.
I've tried Proline Medium - slightly viscous CA cement, which permits movement, to really work the rim in.
I've tried the SUPERTHIN HPI CA cement, which gets EVERYWHERE!!
I decided to do some Google research for a really strong adhesive that will bond alloy to rubber - I run alloy wheels on my MT.
I came across E6000 'Industrial Strength' contact adhesive.
This is potentially petrol and UV sensitive, but is VERY strong once bonded with a required breaking force of 3500 pounds / square inch, and UNLIKE CA adhesives, is elastic. This means it will hold the tyre, take the shocks theoretically, and NOT break, like CA will.
There is an alternative called E6800 that resists UV as well, but I'm trying out the E6000 first.
I took advantage of the 8-hole FG wheel design - my alloys are near-identical except don't have the bolts around the centre - and used 530mm cable ties to spread the load evenly around the rim and pull the new MCD chevron tyres I found into the beads.
I left these for 3 days and systematically removed the cable ties.
First impessions are excellent - EXTREMELY strong - I can't move the tyre 1mm, and flashing is both transparent and can be removed like UHU!!
'Blobs' can be pulled and cut off, and excess on tyres simply rubs off with the finger.
