Phatter...faster...!
sorry dudes! i've been away for a while! the pipe just blows me away...the nylock nuts and bolts need crazy glue!!! top end is definatley there but the low end needs some adjustments....mind u, for running stock 23 and all the added weight of the alum. parts, i think silvia is doin pretty good...now wat can i break next to upgrade now? kkk
put a 8k rpm clutch spring and see how it goes.
with heavy tires you need a heavy (standard) flywheel but the lightweight one with the clutch spring will help the bottom end.
I did it on my TT.
Big change.
I have the same pipe you have, plus clutch spring, light flywheel and billet air filter. The car was very slow from a stand still, now is a whole different story.
