pics for mastiff06
Trebor
manchester...UK
mastiff06 these are the pics you ask me for...i have posted before when i first
joined large scale forums but most where lost as i didn't put them in
a folder on photobucket :clown::clown:
fair play mate thats stunning, i cant imagine how much money an time has gone into it,
only problem id be afraid to use it if it was mine, A PROPER SHOW PIECE,
thanks for the photos :)
glad you like it but this is my oldest one ...you should see my leopard if you thought this was :cool2:
many guys on here don't think i run it :clown:but it has beed run loads
but i strip and clean after each run :blush:
I said it before and i'll say it again, that roll cage is a work of art :)
Sometime in teh next year i'll do one, but all I have is a MAPP blowtorch and a brazing rod.....
well you should be able to sort one with that equipment...smile
this one is solid 10mm steel bar tig welded ....a week of polishing by hand
then nickle plated as i don't like things to shiney:clown:
Brazing should hold just fine. I've seen it done before. Good luck ;)
Trebor, you never cease to amaze me. What a beauty. Did you do the cage yourself or sent it out? Also, what is the purpose of extending it to the front part of the car?
Chris
Chris
Chris i made the cage when i had a proper job:clown:
its made out of 10mm solid en32 steel bar....stands around 30mm higher
than a standard cage i tig welded it then spent near a week polishing it
before having it nickle plated...altogether it weighs in at 5lbs
the rear wing is stainless steel along with the gear cover
they where made from a new jaguar silencer (muffler)
before they where formed round...this was to get the jaguar logo:boat:
i can honestly say keith does run his cars and he can run them pretty hard and fast !! i've had the pleasure of racing our cars at Pleasington a couple of times, but i have to say they really are a work of art...nice one mate, mite need your services sometime in the future!
it was a little short of an arm and a leg.........i take it you aint
seen the rest of me cars then :blush:
ill give you both my legs for it? got a deal :w00t:
iv seen couple of your fg models but got real soft spot for fg marder and i no its not the best model but nothing can beat it for me:balloon:
keep the good work up
also would you make a alloy cage for my marder for some hard cold cash :kiss: and how did you nickel plate all the alloy
cheers
cheers
hi Poof:laugh:i no longer work where i made the bits for me marder as i made the roll cage from 10mm solid steel bar and tig welded it together then took me days to polish it before the nickle plate should have jigged up for making them:laugh:the cage weighs in at 5lbs so no light weight
a couple pics here of marder bits the gear cover is polished stainless steel also the rear wing is stainless steel on a backing of abs to stop radio glitches
l
