poor starting
daroncharles
St.lucia
hello all,
I have a rampage MT v3. after running for about 20 min. it's gives problems to start up again.
am i doing something wrong.
Sometimes they can be really easy to flood after they are warmed up. Your not applying the choke afer you try and restart it are ya?
daroncharles said:
sometimes i would try it the following day and it wouldn't start
Check head of the engine/ Check if it moves and check if there is space between engine head and engine itself.
Offtopic question but were you selling your MT on ebay?
Does it die after 20 or so minutes? Mine would run fine for abt 20 minutes then die...wouldn't start back. It ended up being a vacum in the gas tank. I could remove the cap and it would kinda hiss, then run fine for another 20 or so.
I ended up using a little dirll bit and reaming the vent hole out a little and it's fine now :)
Just something you might wanna check
Parker
