Pop Off Pressure - The pop off pressure is not an adjustment that exists on the carb, but rather a specification that is a combined function of the needle valve size, and the spring rate of the float arm spring. This specification has a wholesale effect on the fuel metering in the 0 - 40% fuel range. Because the pop off pressure has this far reaching range that overlaps with several other metering ranges, we consider it a fundamental starting point.
The term "pop off pressure" refers to the amount of fuel pressure needed to push the float needle valve away from it's sealing seat. Pop off pressure is checked with a hand pump that is fitted with an in line gage. The pump is connected to the fuel input fitting of the carb. The return line fitting is then sealed off with one finger while the pump pressurizes the float chamber. The pressure reached on the gauge when the needle gives way is called the pop off pressure. "Adjusting" the pop off pressure is discussed below. If you don't have a pop off pressure gauge, you should get one that has a gauge and pump capable of 30 psi. (Most Mikuni distributors carry them) At the beginning, it's only important to check that the needle holds the pressure back with no leaking up to the point where it pops cleanly away from the seat. Perform the pop off test several times to confirm the actual pop off pressure. Initial pop off pressures on the Mikuni and Kiehin carbs (unless otherwise specified) should be no less than 25 psi and no greater than 35 psi.
Basically....Don't worry about it as it's preset in the carbs and non-adjustable.
