Rusty Nail
Junior Member
- Reaction score
- 0
Hey guys. I recently bought another MT. I did the break in and was starting to tune the motor and the truck died. I seen that it had proper amount of smoke when running but when I pulled up to do a little adjustment to the HSN, it died and that was it. I couldn't get the thing started one time after that. I thought well I must have flooded it so I took out the spark plug, drained the gas tank, turned truck upside down then let it sit for about an hour with no plug to air out. I put the plug back in and the thing wouldn't even pull!
So I took the pull cage off and looked at the pull assembly and it all is working fine. I manually turned the shaft to see if the piston would turn. It turned but would not make a whole revolution. I took the motor off of the truck to inspect more. While the motor is off it turns over and the piston moves freely. So I put it back on and then it started turning with the rope assembly until I put the plug back in and tried to pull and it tightens right back up. I take the plug out and it turns freely.
Did I destroy my motor. I'm just a newbie tearing things up but I try and figure it but I need some advice. My buddy said it appears that I might need a new clutch or maybe a new top half of the motor. Any help with would really be appreciated. I'm bummed, I haven't had the thing but two months. My other MT works pretty good and it's a few years old now.
