Possible Stupid Question
jathomas3
Ok, so I'm having trouble trying to take my motor off of my XBE. I have the motor off of the mount but the motor plate is blocking the set screw that holds the pinion on. Am I missing something here? Any help would be greatly appreciated. Thanks!
Ok so I figured out two things. One, it was a stupid question. Two, the pinion slid towards the motor on the shaft and that's why the motor plate was blocking the set screw. I'm thinking the stock motor got too hot and loosened up the threadlock. Time for an upgrade!
Thanks anyway rcdad! I just ordered a TP Power 5692 1100kv. I'll run that with the Mamba XL2 on 8s. I also ordered a 12 and a 13 tooth pinion which I'll run with the stock spur gear. Hopefully that will be a winning combo.
I am looking forward to my experiences as well, just not looking forward to my credit card bill!! LOL!! Do you have a link to the 5840 and 5850?
I've picked two y and one d... I'll have to find out which will fit and work with the stock esc. I've also ordered Robinson pinions ranging from 9 to 16 t to check temperatures and speed. I've got all cams from 7075rc so I'll post info on that also.
