GoffeeRedCat
Well winter is coming in Chicago!! I know I need to waterproof the servos and my radio box..I will be doing that soon!! I need some suggestions on how to maintain the XT in the winter time (pre-run, and post-run)
Negative on the balloon trick...my receiver is double sided taped on my boxTheKaiman said:You can use plasti dip on your servos. Put your receiver in a balloon and zip tie the end. I live in eastern Pennsylvania and it gets brutal here in the winter sometimes. Be careful of your plastics they can break easily in the cold obviously.
Thin gloves..lolRCDAD said:Just wondering...Do you guys tough it out and drive bare handed, or do you make an attempt of handling the transmitter with gloves on?![]()
You would have to remove and replace. Small PITA for weatherization. You could also seal the seams of the box with electrical tape prior to snowy/wet sessions.GoffeeRedCat said:Negative on the balloon trick...my receiver is double sided taped on my box
I'll just seal the receiver box...but I'm more concerned about the after run! Since we use tons of salt or grit on the roads here....I wanna know what you use to remove snow/slush/grit/saltTheKaiman said:You would have to remove and replace. Small PITA for weatherization. You could also seal the seams of the box with electrical tape prior to snowy/wet sessions.
I just tough it out, I only wear gloves when I ride my sled (snowmobile)RCDAD said:Just wondering...Do you guys tough it out and drive bare handed, or do you make an attempt of handling the transmitter with gloves on?![]()
ohh wow!! never thought about using that!! I have some in the garage!! I usually use plastidip... that made your servo a little thicker and difficult to put back!! definitely going to use this stuff!!!!!Trip.. said:I just tough it out, I only wear gloves when I ride my sled (snowmobile)Camp Dry http://www.amazon.com/Kiwi-Camp-Heavy-Water-Repellent/dp/B000HJ7CLY is a silicone spray that will waterproof your electronics. Just spray the poop on and let it sit for 2 hours, then go play in the snow.
Great tip on Camp Dry!Trip.. said:I just tough it out, I only wear gloves when I ride my sled (snowmobile)Camp Dry http://www.amazon.com/Kiwi-Camp-Heavy-Water-Repellent/dp/B000HJ7CLY is a silicone spray that will waterproof your electronics. Just spray the poop on and let it sit for 2 hours, then go play in the snow.
