Yannik
Hi,
I have a question concerning the Onyx 220 Battery Charger. I have a new receiver battery (6v, 5000Mah) that I just started to charged so I put these settings (below):
Bat. Type: NI-MH
Capacity: 5000Mah
Current: 0.9A
S_Timer: off
Peak: 3-7mv/c
Trickle: Auto
I've been told to always put the S_Timer Off and the Trickle on Auto. I don't if true or not?
After charging 5hrs and at 300min, the charger started to Bip and the display showed Circuit Error. It was around 4100Mah charged when it started to bip. I unplug it from the wall and plug it again but it didn't saved the work already accomplished!
I truly don't know what to do with this issue? Any suggestions??
Thanks,
Yannik
Bat. Type: NI-MH
Capacity: 5000Mah
Current: 0.9A
S_Timer: off
Peak: 3-7mv/c
Trickle: Auto
Thanks,
Yannik
