vassilisG
Hi guys ,
Project 3 is 50% in my mind , 30% made , 20% talking about.
The idea :
- 1/3,5 scale
- on and off road : special suspension to give 7 cm travel for off road use and 4 cm for on (adjustment in 2 min ).Association (hydraulic )
between front and rear suspension ,which you can lock for on road use ( adj in 5sec ).7cm or 4 cm distance from
the ground.
The association of front and rear suspension gives , among other things, differently amortization so you can drive on and off .
- 4 wheel drive or 2 wheel drive ( front or rear drive )
- Light weight tubular chassis ( about 2 kg with arms ) .Tubular or acetal ( type of industry plastic ) arms , full adjustment , camber caster ,toe in - out.
- 2 disk brakes ( like Lotus7 )
- 3 - 7 hp engine.
- about 13 kg
- on and off road wheels ,( 4 + 4)
- with the .... known quality of parts.
What do you think about it ?
The idea :
- 1/3,5 scale
the ground.
- 3 - 7 hp engine.
- about 13 kg
