Pull start Alternatives
DanSpd
Are there any alternatives (such as ez-start) to pull start?
You basically start the engine with screw-gun if you use this start right?
chevy said:
no the $89.00 kit only works with cordless drills or you can buy and adaptor to go from screwgun hex shank to straight shaft they have the adaptors at www.amazon.com type under search Milwaukee 49-22-1560 then you can see it! or the cheaper way would be to just weld a hex bit to the end of the starting shaft! then you can use a screwgun, I included a pic of the adaptor amazon sells!
Yea, was talking about cordless screw-gun. I dono if there is different name for it so yea lol...
Well, the screwgun start looks awesome but expensive. So I think I either buy new more reliable pull start or save up for screw gun start.
Is it possible to find those pull start systems at home depot, wallmart? or is it special pull start
chevy said:
oh no you guys are giving me second thoughts on getting one! you don't think thats a good idea??? I don't need somthing thats gonna damage the engine it not worth breaking pulleys and flyheels i've been around 2 stroke engines for years just not in rc cars,and I know how tempramental They can be! in my experience having clean filters (gas and air), a good carb, thats adjusted correctly, and the right spark plug you shouldnt have to pull more than 3-4 times to start so you not going to need these kits right?
right,if you got all that done +some dustfilter for pullstart it will last long enough,after 1year i still got the original pullstart in my tt and its working!
Can regular pull start be found at wallmart, homedepot, etc?
Cause engine is seems to be fixed but pull start broke...
