Pull start problem
Madhd
Junior Member
Hi
this is my first post...I got a Volcano s30 for x-mass i started the break-in procedure on the truck and after the 2nd tank of fuel my pull starter wont engage anymore so i cant start it....i did read something about a one way bearing that is slipping....could it be fried just after 2 tanks of fuel?
could use some guidance.
thanks
Take the pull start off and clean off the shaft and bearing put alittle wd-40 on the bearing that should fix it. also look at the hex to make sure it's not broke
