pulled trigger no go?
Rsaint
Ny
last week i tried to tune my dr but unfortunately my pull start broke, so bought a new one then bought a new remote. i tuned the car out idle is good low speed good but for some reason when i pull trigger it doesn't run but when i push it shuts off. i bind the remote but im just confused if i missed something.pleaase help:confused:
Fs gt3 2.4 ghz. The low speed needle sounds good but the idle screw I been messing with. Ok I'll try. There is no other way to put the plugs on the reciever right but my steering servo had to be in reverse mode to right when I steer right.
It is common to have to reverse it. Without the vehicle running you should turn on the electronics and make sure you have full travel of both the steering and throttle/brake. You also want to set your EPA or end point adjustment to make sure your servos are not pushing too far.
High idle
Last week pulled trigger no go....today from 6am until 6pm. Change carb to 813 walbro, new clutch 8k, new air filter and velocity stack. Took a while to start finally figure out that my throttle needed to be reverse also. But seems like the idle is too high. I tried playing with the idle screw and low speed needle and throttle control set to zero but still high idle. The good part about it I was able to play with it a while. Do they usually idle the high?
