Q. Battery for high voltage servos
1RC5
I just purchased all high voltage servos for my Rampage MT.
Throttle: SV-0220MG
Steering: Dual HS-5765MH
Question: Am I better off with a 5000mah Nimh 6v or a 4200mah 2S Lipo?
I need to buy a charger regardless. I know the servos will run a little bit slower with 6v, but any other things to consider? Which pack would last longer, 5000mah?
Thanks!
6v pack will last longer. As higher battery voltage, more amp used by servos . So with same battery capacity(mah), less volt battery will last longer.
I've searched and can't confirm that the killer.rc 4200mah 7.4v 2s lipo will fit the stock MT box with both steering servos.
Can anyone confirm this? If it doesn't fit I'll go with the venom 5000mah 6v humpback but was hoping to use a lipo since I just got HV servos.
Thanks
