Question about futaba aluminum servo mount
jacosj
allendale, michigan
Question for you guys.....I'm getting some parts together before my Rampage arrives and I bought 2 Hitec 805BB servos. Do I need the redcat aluminum futaba servo mounts part # 050010b for the servos to fit? If so, how many do I need? Thanks
the aluminum futaba will work with the 805bb on the opposite side the radio box is you only need one mount and one, servo the 805bb if fat and wont fit under the radio box.
Not to hijack what appears to be a dead thread but....
Are the Futaba Mounts the same hieght as the stock mounts?
gee the thread aint dead, No I'm sure its slightly taller just enuff to fit the thickness of the 805bb and the hitec 645mg with a small gap between the two servos.
I made some mounts out of lexan before I knew about the futaba mounts. Basically the same size as the stock mounts. I was looking today that if the mounts were shorter where the throttle servo was sitting basically on top of the steering servo it would help with the clearance around the HPI airfilter. When the motivation hits me I will shorten the ones I made and see if it helps. I would like the futuba mounts but will have to see know how the adjustment works on these. Thanks for the response chevy.
By the looks of it should be able to lower it about 8-9mm. Hmm could even go lower for a better angle to the throttle if I had a half size servo........
Just use the fut alum servo mounts the sfl10 fits right in and its the same height ive use them on mine and ive got 2 sfl 10 servos on the truck
