Question about my baja
ST402flooring
Active Member
Nebraska
Hi guys! I got a question. After I ran my baja tonight, the thing in front of the air filter started leaking gas. It's the circle part right behind the air filter it's where the clamp is on it. It's leaking from under neath. Any ideas what caused this? I will look it over inter morning, now my whole garage, and basement smells of gas!! Thanks for your help.-Steven
Sounds like either your primer bulb has split (yellow dome) or a fuel line has come off/loose/split. The thing behind the air filter is the carb btw! The bottom fuel line is the feed from the tank so if it has come off it could be having a syphon effect and slowly emptying the tank.
Hey mike! I just tightened everything up then no leak!! Lol I forget about having to tighten things up a lot. That's problem most of the time haha. Nice to meet you! You guys always give the best advice. I'm glad I joined this forum!!
