Deluge said:
I don't use the 813 because I don't want to have to constantly replace the throttle shaft.
I have well over 20 gallons on the same GP290 and 813, no shaft issues for me...
It's unfortunate that a few inexperienced tuners had carb issues, now the 813's reputation is in the shitter... The 813 is by far the best carb I have ever played with. I am a small engine mechanic by trade and I still will vouch on the behalf of the 813. I will fault the tuner 10 times over before I fault the carb.
In the right hands, (In my opinion) the 813 is the PERFECT carb for R/C use. IF YOU ARE NOT A CONFIDENT TUNER, the 813 can be a bit tricky. It's an excellent carb if you know what you are doing and if you don't... well that's why they make the 990. Still a great carb.
In the full scale world people swear by Holley, just as others swear at them. It's all a matter of your abilities, if you can't tune a carb for poop you are going to hate a Holley, just as you are going to hate an 813. That's why the Edelbrock 600cfm is so popular, but you'll never see them on a Top Fuel dragster. Think John Force has a pair of Carters/Edelbrocks on his Top Fuel Funny Car? I think not. Edelbrock revamps old Carters to be used as street carbs for people that don't know how to tune a carb properly. Zenoah does the same thing, but Zen calls them the
668.
The same thing applies to the 813. It has an accelerator pump, something that no other small engine carb has. This little device completely eliminates the low rpm/off idle bog. It can cause tuning issues if you don't know what you are doing or if you run a 1/5th scale like you run a nitro and are constantly snapping the throttle. All of the throttle snapping shoots huge amounts of fuel into the cyl and causes the plug to foul. It's not the fault of the carb, it's the fault of the tuner/operator.
The throttle shaft wear is such a simple fix that it really shouldn't even be mentioned, but yet I still see this constantly, "The 813 has a shaft problem."
Well I guess it does, it needs a small drop of silicone/shoe goo to remedy the problem. 3 cents worth of silicone to have a perfect running carb is a small price to pay. The unfortunate thing is most of the people that have a problem with this carb is because they don't know how to tune a carb properly to begin with or are just regurgitating bullshit that they read on the internet.
There is nothing wrong with the 813.
