Question Regarding Engine Upgrade
redcatuser
Junior Member
I bought a Redcat Shockwave which comes with VX .16 stock. If I'm not mistaken I can mount a SH .18 to it? Can I use the clutch assembly from the original motor? Would the stock exhaust manifold work with the SH .18? Any other things I should consider when doing this? Thanks! :D
Not sure.......but most engines that I've seen use similar sizes.
I think there are ranges tho...
Like .21 and less, then "big block" .21 - .36?
The clutch and pinion should swap.
Also check the location of exhaust and style of exhaust mount [bolt on / spring mount].
I ended up going with the VX .18 instead since it has more power and picked up tuned exhaust with it. Hope it works well! Thanks for your feedback!
