Yannik
- Thread starter
- #21
Should it be completely silent or it will still make a tiny sound?blak__jak said:yannik to answer your servo question your best bet when first getting an m/t or anything with duel servos is to pull off the servo arms turn the t/x and r/x on and let the servos center themselves then reinstall the arms as close to 90 degrees and even with each other as possible, you may have to adjust the steering linkage at this point to get it right, this should eliminate the buzzing and any pressure they were placing on each other.
