yeah i have spark and checked my gap with a business card' date=' i have not got this motor to start at all its still brand new. the seller said on his page that the long block will fit ''fuelie'' which my HY motor had a fuelie sticker on the pull start so i assumed it would be fine...seller does not want it back i cant get my money back i made a case on ebay and i lost the case because i bought the long block knowing that i was not 100% about my HY & seller was not sure about compatibilty of the parts prior to the sale so bad luck for me[/quote']Well good spark is the only concern I'd have on your end of the parts swap. The fitment of the flywheel and coil. And you have that. You also have a knowingly good carb I'd assume. Your pipe for the exhaust. It should run. Unless low compression or the carb needs tuned a little. Is the carb on its recommended base settings? Can you feel good compression pulling the cord?
I know Zenoah is a different animal but don't Rovan run the same CY/HY all the others do?I had a similar problem trying to take parts from a km 30.5 and putting on a zenoah engine. I even purchased a new flywheel and coil from km only because of cost. Didnt work. I got lucky and the flywheel got damaged some how and a few fins broke off. Picked up a cy one on sale. Now runs great. I Never put 2and2 together but after the previous post it makes sense now. Try a new flywheel
I run a 29cc Zeni found a scz 29cc motor for sale just got that going and holy poop where has this been all my life
Maybe a Zen?they may do so for a few models but im pretty sure this R320 is rovan built
You'll have to keep us updatedreed case power i wonder how long the drive train will last
