Racers rear tire toe in tip.
PhatDad1
This makes a big difference for the better the way my buggy goes around the track.
Using stock HPI baja rear hubs. File or grind away some plastic on the hubs so you can adjust camber.
Pic of hubs installed. I also use the HPI front wheel hubs so I can use there wheels. You will also need to use HPI part#85416. Stock part will not allow ball to pivot to the angle that is needed. I also had to cut off about 3/8" on the upper turn buckles. You need to turn these in more than the stock setting. I will be making a conversion kit with all the parts you guy will need to make this mod. Inexpensive and worth it for better truck and buggy control.
I have the #4 adjuster on my buggy. You loose some top end and gain more straight line control.
