Racing Rampage XR Aluminum Rear hub and front C hub and Stering Knuckles
jjrosello
New Member
I up graded my Ramage XR to the aluminum front and back suspension and I wend and order the rear hub and Front c-hub and steering knuckles and received try to install rear hub and the wheel hub wont fit the hole wont line up for me to insert the pin is there a reason why it not lining up and what do I have to do to make it line up
Man I just ordered thier front c hubs and steering knuckles in aluminum from rampage shop and this is not his fault but Do Not Buy Them they suck if you put them together the way your supposed to the steering knuckles need to be ground down some so they will freakin move and that’s IF you can even get them to go into the c hub ,what a freakin rip off,I’m pissed cause they weren’t cheap!!
