Racing set-up/Bashing set-up.
IMADMAN
USA/Hawaii
Would like to hear from you folks how you run your set-up for racing or bashing.
Powerplant, shock oils and setting,diff set-up, caster/camber, toe in/out. Wheel/tire combo.
Like most folks on a limited budget and would like to get a general starting point without spending money on unnecessary items. Right now I have a stock MT-(Thanks Skater229)! But would like to change it, into a racing truggy so at the very least i'm trying to get the HPI baja tire set-up or equivalent.
Here's what I have done and so far it will servive and land most jumps near the 20ft range.
Upgrade kit (duh!)
heavier shock oil, and turn down front preload 1/2 inch
move shock mounting positions front and back to inner most hole
install 6,000 rpm clutch spring (8,000 tends to break things:eek:)
stock toe in rear, front toe out 3 degrees
rear camber -1 degree, front camber -3 degrees
Heavier rear diff oil 20k losi, fairly light front 4k losi (these things don't turn so some slider actions is required in tight tracks.
and last but not least it has to have fuel tubing in the drive cups to keep the shafts centered.
There's my setup in a nut shell, I will be posting video soon of it running and clearing a 5' X 13' tabletop.
Sorry about that it's still Monday morning:rolleyes: I run 50Wt rear and 70Wt front oil. It seemed a little heavy at first but after running for a while it's nice to have the extra dampening for the extra weight of the truck.
