Rampage Drive Cup Saver
lords
so is there another place to get these from?
Rampage Drive Cup Saver / Pin Retainer Sleeves, 12 Piece Set
You could try the DarkSoul Toobz. They're made for the Baja, but they should work. Or you could get yourself some steel tube and make your own.
The toobz wont work. The diff cups are too small of an outer diameter. A rampage diff cup + a Cat5mfg ring= the same outer diameter of a stock Baja diff cup.
