jwoods81
So I received my Rampage MT today so I took a trip to my brother's " mwoods269 " house to install my components and compare to his rampage MT that arrived 2 days before mine.
We both installed the following products:
DDM exhaust Pipe - Mikes was chrome and mine was black
Super Bee Gas Kill Switch
HiTech Servo - HS-645MG
Lock Tight on all important areas
We did a complete video on the un-boxing and items inside at [ame=
[MEDIA=youtube]S_wCd9wqUYg[/MEDIA][/ame]
We got everything dialed in and decided we just had to take the trucks out. While my brother was trying to keep his truck started I was taking mine around slow and easy. After a few low laps I just had to gas her a few times. After almost taking my niece out "sorry girl" I took one last lap around and ended up flipping the truck " 3 rolls at least" which landed on it's side. My brother drove his truck next time mine and did a slick move to push it right side up. I gave it some gas but had no steering. Here is the results:
Front Body Post = Broken, Plastic Body = Cracked, Front Right Steering Assembly = Broken. I found all parts need for replacement except the steering assembly part. It's not even listed with a number in the manual.
Also with the DDM pipe installed I noticed it is WAY to close to the gas tank and with the heat it melted the cap "just a little" so I will be taking the gas tank out and placing it back in with the cap on the right side of the truck.
I had also purchased the Bow-Tie Off-Road Tires mounted on Desperado rims Front Part # 1150-13
Rear Part# 1151-13
I'm really not happy with the tires as I think they are way too small for our trucks compared to the factory rims/tires. I also did not know that the front set are very thin and the rear is larger. I opened both packages but did not mount them as I hope I can return them.
Check the pictures out below and let me know what you think.
Rear Part# 1151-13
