Rampage MT Diff Oil
JLW4291
Palastine,Texas
I have the Rampage MT I would like to know what everyone is running as far as weight of oil in the diffs and the shocks. Thanks in advance for the advice.
i really don't know about the diff oil. i'd figure something really thin. i'm going to fill the inner case (planetary case) w/lucas oil stabilizer & then fill the outter case (pinion & ring gear case) w/lucas red n' tacky #2. a lot of people stuffed their atv rear diffs w/lucas red n' tacky #2 grease & never had an issue & those diffs were ran harder than these ever will be.
as for shocks i'm using 45wt.
I have some rc grease called Gorilla Snat that I used on 1/8 scale diffs but as for the diffs I used 30k Ofna diff oil. Would this be a good combo for the MT?
on the xb, i use losi silicone diff fluid. this is the diff itself- not the outer ring-pinion gear. 10,000 wt rear. 7,000 or 10,000 wt front. i donot have a mt. just a guess- 10,000 or 15,000 wt both ends?? it does thin out with heat some-- perhaps others could have a better idea.- people that actually have tried assorted weights on the truck.
