Rampage MT receiver problems
dalentx
Junior Member
ok...im having receiver probs again...my battery pack is charged up...batteries in my radio are good...so whats a better receiver to put in the MT other than the stock one..i replaced it once already...its like 50ft or so from me and the steering an throttle don't work...have to walk towards it some for it to go again...the stock one is junk to me....im wanting a better one
Go with a Futaba system. All issues should go away. I tried flysky with my MT, It didn't like the interference from the coil. It would glitch when running, work perfect not running.
This will be my 3rd one when I replace it...this is annoying hate walking to it to get it to go again
What futaba system did you go with
That radio system will allow you to run 7.4v lipo receiver battery and servos too. Wish I would have went that route long ago. Such a huge difference
well my MT runs on fuel...2 cycle...would this system still work with my truck
I have the Rampage MT also. That is the truck I am talking about using the Futaba 4PLS system in. The receiver that comes with it is lipo capable meaning longer run times, use of higher voltage servos for steering and throttle, plus led lights and stuff.
I have the Rampage MT also. That is the truck I am talking about using the Futaba 4pls system in. The receiver that comes with it is lipo capable meaning longer run times, use of higher voltage servos for steering and throttle, plus led lights and stuff.
Ok....what are some good servos to use
Rereading this makes me ask. How do you fasten the receiver in the box? Do you either velcro it down or servo tape? Do You wedge the battery down in place or velcro? I have seen a friend first hand learn an expensive lesson not fastening the battery in some way, it smashed the board on his super bee kill switch. Yours sounds like an antenna wire problem, which unfastened can easily happen.
My antenna is still attached...last time this happened the receiver was bad an got one from redcat. I thinks its bad again looks like...my battery is just inside the box
Reason I ask if you fasten the receiver down is that it is not good for it to beat around in there. I usually velcro the bottom of the rx to the box
@dalentx +1 on the futaba radio. Get one and be done, literally! It's reliable and the range is perfect. Perso I have the 4PLS but you can go with a 3 channel if you don't need the 4th one.
Right on @designed2survive. That system is awesome! Especially if you use it to its full capacity with a complete rx lipo system. Best thing I have done since the superbee kill switch.
I know this is a kinda necro - I switched to a Futaba receiver, and I was wondering if someone knows of a decent lipo that will fit in the battery box? Or are they all just the wrong shape, and have to be run externally?
