Thanks for the reply! I took this in as part of a trade so I can’t answer some of your questions but here’s what I know. Redcat Rampage MT , used. Guy claimed it work so I guess that’s up in the air. 30.5cc engine. Not sure what type carb. Plug does not look as wet as it should, if that makes sense. Firing outside the motor . I have installed a drill start system on it and it is turning it over fast enough to start the motor but not getting a pop.Can you provide a lil more info? What model? Is it brand new\old? Was it working before? Engine? What type carb? Do you have all stock parts? Is plug wet when you pull it? When you say its firing, is it firing when its outside the engine as in a test or are you getting a pop when installed?
If its firing youre probably not getting fuel. Thats my guess with limited info.
OR -
The other end of the spectrum. if its not starting its probably getting too much fuel and being flooded.
The guys here helped me work thru my issues. Now I do the basic Choke on \ 2 Pulls \ Choke Off \ Pull Till she cranks seems to be working for me.
