rampage with zenoah 4 bolt ported
Sounds very nice you have to look out for them front wheel stands on the brakes. I ran my TT this last Saturday and at 35 to 45 mph it did that and flipped 2 times into a apple tree. Thanks to my bracing all that broke was the lower and upper arms lucky lucky. keep the videos coming.
If your brakes are that tight its too tight. My first rampage I got used had them that tight. When that tight it will wear out the center hex of the brake rotors and the aluminum hex they ride on, both at an accellerated rate. I have pictures of the accelerated wear to prove it. Set linkages to soft brake/soft throttle w/springs or fuel tubing (easy on the throttle shaft of the carb and the aluminum parts of the drivetrain during braking).
Post #4:
http://www.redcatrampageforum.com/showthread.php?p=26631#post26631
