I believe that clutch spec is for the center screw. If the clutch shoe bolts are too tight they won't work properly. I like to just snug those up with some red loctite.Albert said:any idea how tight to go with that center one.....thank you
Lmao...hahaRCDAD said:Clutch bolts to tight from the factory? That's a first.Glad you got it sorted!
Couldn't agree more !I would say you have a loose set screw behind one of the gears.don't let it sit and idle there is no need to do that after the first tank or two drive it like you stole it. I'm sure most senior members will agree
